Chromoly axles: should I notice a difference?
I recently broke a front axle on the trail, so took the "opportunity' to upgrade to USAlloy front axles w/CTM ujoints (Northridge special!). I had it aligned and got the wheels balanced at the same time.
The jeep seems to drive "heavier" now, so my question is: are the chromoly's + CTM joints heavier than stock? Would they feel heavier? If elves had swapped them out in the night, would I have even noticed? If not, any ideas what it might be? It feels different at slow (parking lot) speeds, and on the highway.
It has to be a change in the alignment. Do you have before and after measurements of what your toe was set to? If you didnt have enough toe-in before, or even toe-out, the slightest steering wheel adjustments can cause it to feel "darty" and it would also have more of a tendency to follow the grade of the road and ruts. Maybe this was actually corrected, and now feels "heavier?" Its the only thing I can think of...
Thanks, everyone (including the wisecrackers
I'll check the alignment printout when I get home. I'm sure it lists the toe-in, etc. I hope it also lists the castor.
The shop that did the alignment/balance is very competent, but doesn't have a lot of experience w/lifted rigs. He does mostly passenger cars, so maybe he set the castor wrong. I saw another thread tonight where someone was told to put it to 5-6 degrees.
)I'll check the alignment printout when I get home. I'm sure it lists the toe-in, etc. I hope it also lists the castor.
Much like everything else in life it's a compromise but the Jeep handles great.
The compromise is the angle it puts on the front drive shaft CV joint at the T-case.
