LoD Signature Mid-Width: Fog Light Issue
Old Mar 12, 2009 | 03:53 AM
Macavity's Avatar
Question LoD Signature Mid-Width: Fog Light Issue
Ok, so I drilled out the hole on my factory fogs so they could slide into the mounts on my LoD Signature Mid-Width, but they didn't line up properly. Just for kicks I flipped them upside down (the alignment screw facing up) and they slid into place perfectly.
The problem is that now they light up the sky instead of the road. I've adjusted the screw as far as it will go and I can't get the lights back on the ground. In fact, they now aim higher than my headlights.
It's a great looking bumper, but my fogs are now completely useless unless I'm looking for cats stuck up in the trees.
Any suggestions?
Old Mar 12, 2009 | 04:53 AM
Mine were tight, you just have to force the lights a little onto the bolts. My lights aim just right. The LOD bumper is a great bumper. They do a great job on quality.
Old Mar 12, 2009 | 06:50 AM
Macavity's Avatar
I'll pull them off when I get home and try again, but I'm pretty sure I got forceful with them during the install, they just wouldn't line up. Slipped on with no effort when I flipped them.
Old Mar 12, 2009 | 07:19 AM
nachoninja's Avatar
If you haven't already, try switching the left to the right and vice versa, I had the same problem with pointing up to the sky with my Rugged Ridge bumper.
Old Mar 12, 2009 | 07:20 AM
wayoflife's Avatar
JK-Forum Founder
try to identify which mounting stud is giving you problems and bend it over a bit with a pair of vicegrips.
Old Mar 12, 2009 | 09:45 AM
I installed mine before i put the bumper on the jeep. But also try using a deep well socket and place over the mounting hole and tap on the back of the socket, this is on the holes that are tight.
Old Mar 13, 2009 | 06:49 AM
Macavity's Avatar
Thanks for all the tips. I finally got them aligned last night. They're still upside down, but I don't care as long as the light goes where I want!
