Lift Question
Old Mar 15, 2009 | 11:11 AM
BBirish's Avatar
Default Lift Question
I just bought a teraflex 2.5 inch budget boost its scheduled arrival date is march 19th. I also have 3/4 inch spacers for the front to level it out.
My question is will i have to change anything like the trac bar or my driveshaft since the front will have 3.25 inches of lift? thanks
Old Mar 15, 2009 | 11:23 AM
greenamphibious's Avatar
looks like a 2 door in your avatar. You are probably going to get more than 3.25 lift. the coils alone will give you 3". Your DS may become a player. I would recommend an adjustable front trac bar but it isn't required
Old Mar 15, 2009 | 11:27 AM
BBirish's Avatar
sorry i should have specified its the lift with the spacers and shock adapters so im thinking it will come out to exactly 3.25 inches of lift up front.
Old Mar 15, 2009 | 04:26 PM
nangulator's Avatar
You are going to want 35s after that lift You may want to consider an adjustable front trac-bar and a re-location bracket for the rear, as far as the drive shafts go, I am not sure on a 2 door
Old Mar 15, 2009 | 05:29 PM
BBirish's Avatar
i know i do want 35s but im gonna let these rubi tires wear out first i just dont have enough money
Old Mar 16, 2009 | 01:43 PM
BBirish's Avatar
bump....does anyone know if the teraflex 2.5 in spacers + the daystar 3/4 inch leveling spacers will cause any problems ????
