Extra .25" lift?
Old Mar 16, 2009 | 06:41 AM
officer_vince's Avatar
Default Extra .25" lift?
Can I go with an extra 0.25" of lift without getting a new driveshaft in the rear? I already have the 3" Zone kit.
Thanks!
Old Mar 16, 2009 | 06:46 AM
wayoflife's Avatar
JK-Forum Founder
well, if have an auto and you aren't tearing up your front drive shaft now, your shocks are most likely short enough to prevent it from happening even if you were to install 1" of additional lift. if you have a 2-door, you already need a new rear drive shaft and it's just a matter of time before it lets you know that for sure.
Old Mar 16, 2009 | 06:51 AM
2DR 6speed.
I really don't want to drop the $700+ for a new driveshaft...but if I don't have a choice....
Old Mar 16, 2009 | 06:54 AM
wayoflife's Avatar
JK-Forum Founder
Originally Posted by officer_vince
2DR 6speed.
with a 2-door 6 speed, you'll be fine with the front drive shaft that you have now. for the rear, you really will need to replace it and install as set of adjustable rear upper arms to set your pinion angle sooner than later. once you see grease being sprayed out from the CV boots, it'll just be a matter of time before you hear the bearings inside go.
Old Mar 16, 2009 | 12:17 PM
It's alot of cash to drop but I guess I don't really have a choice.
Old Mar 16, 2009 | 12:21 PM
wayoflife's Avatar
JK-Forum Founder
no, you don't have a choice but you can keep driving on the shaft that you have now until it goes bad. this can take anywhere from a few months to a year and it will give you notice when it's on its way out.
Old Mar 16, 2009 | 12:25 PM
Haha good to know.
Thanks!
