ProComp steel wheel clearance issues
Old Mar 16, 2009 | 04:18 PM
Stuka's Avatar
Default ProComp steel wheel clearance issues
Ok, I know several people are running these. Pro-Comp Series 97 in 16x8, 4.25" BS. They are about 1mm from the caliper. Has anybody had any issues with this? Getting things caught up in there or similar?
Photo is attached.
Old Mar 16, 2009 | 07:57 PM
MOWrangler's Avatar
Looks like it is time to get out the grinder and give 'er a little more room.
Old Mar 16, 2009 | 07:59 PM
Stuka's Avatar
Yeah... But I am afraid of voiding my warrantee if I do. I had thought this was only an issue with 15" wheels, and that 16's were fine.
Old Mar 16, 2009 | 08:45 PM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
maybe the backspacing really isnt 4.25?
Old Mar 16, 2009 | 09:55 PM
Hellbound13's Avatar
Mine are like that too, have not had any issues. What issues would it cause?
Old Mar 17, 2009 | 05:23 AM
Stuka's Avatar
I was just wondering if anybody had ever gotten anything caught up in there. Small pepples, or grit from mud or the like.
But with the lack of responses, I am going to assume not.
Old Mar 17, 2009 | 05:46 AM
officer_vince's Avatar
Mine were even worse...they touched the caliper bracket when I installed them.
I had to put 30mm of aluminum spacer behind the rim to clear it.
Old Mar 17, 2009 | 11:55 AM
Stuka's Avatar
I am thinking I am going to have to do the same just to be safe. Where did you get yours?
Old Mar 17, 2009 | 12:01 PM
Stuka's Avatar
Oh, just found these. These should fix my issue:
http://www.go-fast-parts.com/5733985.html
EDIT: These are 0.125" thick. They are safe to use. Full blown spacers are WAY to thick for what I want.
Old Mar 17, 2009 | 12:07 PM
nclehmann's Avatar
Do NOT use those types of spacers!
Extremely dangerous. They don't allow the lugnuts to fully thread onto the mounting bolts. Use the type that bolt onto the plate and have their own threads like the ones from Spidertrax, Teraflex and Rugged Ridge.
Attachment 20875
