RC 4" lift and ride quality.
Old Mar 17, 2009 | 07:29 AM
Default RC 4" lift and ride quality.
I am currently running the RC 4" lift and 2.2 shocks. The ride quality to me is somewhat stiff, especially in the rear. My question is, what change in ride quality might I see by installing the LT OME shocks and keeping the RC coils? I would rather not spend $360 on shocks and not see a noticable difference.
Any experience or advice would be much appreciated.
Old Mar 17, 2009 | 10:48 AM
Dr.McNinja's Avatar
Not much that I could think of. Your springs are the major component to the stiffness.
What suspension did you have before? I had the Rubicon/heavy duty springs and shocks, and to me the RC is about the same.
Old Mar 17, 2009 | 11:12 AM
hammerhead's Avatar
The 2.2 shocks are very nice shocks it's not them it's the springs that are stiffer. If you just installed it I would drive it a while as the springs will get a little less stiff after some time. I would also check your tire pressure, my tire shop had them set a 40 psi and I lowered them to 28 psi. I thought the stock suspension was to soft and like how it stiffened the suspension up. I think it would be way to tippy with a 4" lift and suspension as soft as stock.
Old Mar 17, 2009 | 11:27 AM
I was running stock X suspension prior to the lift. The front seems fine, but the rear is pretty rigid. It almost seems like I might have gotten Unlimited springs instead of the 2dr springs.
Old Mar 17, 2009 | 11:30 AM
bigbluejk's Avatar
I doubt they have different springs for 2dr and unlim on the rough country lift... but I could be wrong.
Old Mar 17, 2009 | 11:35 AM
I am currently running 30psi in my KM2's. I will go down to 28 psi and see if there is much difference. I definitely do not feel tippy with the set up I have now. Just looking for a little more comfort on the road.
Old Mar 17, 2009 | 11:39 AM
hammerhead's Avatar
They are different.
Old Mar 17, 2009 | 11:40 AM
I believe they do have different spring rates. They sent me a 4dr kit at first so I called them about it. They said that the difference in the two lifts were the rates. I shipped the coils back and they sent me out some for the 2dr. At least I hope they were for a two door.
Old Mar 17, 2009 | 11:42 AM
If I was to change just the springs, which direction should I go in for a better ride quality? I would like to stay with the 4" lift.
Old Mar 17, 2009 | 11:50 AM
bigbluejk's Avatar
Northridge sells teraflex springs. you could use their 3" spring it will give you 4".
