TeraFlex 2.5"- BB vs. Coil
Old Mar 17, 2009 | 07:47 AM
sirkle's Avatar
Default TeraFlex 2.5"- BB vs. Coil
Well guys, I'm at that stage where so many of you have been already, and I'm finally ready to pull the trigger on my first lift for the JK. I've read and read, and used the "search" function to my maximum potential, and there are some incredible threads with priceless information on this topic on this forum. However, between the 100 or so threads I've perused so diligently, I've yet to come across one that answers all the questions of Budget Boost vs. Coil Lift. Of course, there are many manufacturers of these type lifts, but more specifically I'm referring to the TeraFlex models in 2.5" versions.
I've got a new Rubicon Unlimited with the tow package, so I believe I have HD springs (right??). I'm gonna run the stock tires for now with 1.5" spacers, and I'm mostly interested in getting the JK up off the ground a bit more and leveling her out. I hate that factory rake!! As for now I won't be running a bumper or winch, but I do plan to in the future, $$$ provided (cross your fingers for '09!!) SO, here's where I think I'm going:
TeraFlex BB or Coil: 2.5", Spidertrax 1.5" spacers, and TeraFlex 1/2" Front Coil spacers. Pretty dang common setup.
Now instead of this being a total "help me" thread for a nube like me, I'd like to get some of you guys with experience to compare the pros and cons of the BB and the Coil lift options from TeraFlex. It seems that they are excellent products, and lots of people tend to run one or the other as their first lift, so why not debunk some of the myths and clear the air?
From what I can tell, the main advantage of the coil lift is added articulation. But, if you run the shock adapters, with stock Rubi shocks as I would, wouldn't that limit you to stock articulation anyway? In other words, wouldn't you be in the same boat as running the BB with shock adapters as far as articulation goes? Also, if you've got the Unlimited with tow package, don't you already have HD springs, and therefore the BB would be just as beneficial? We're talking about maybe $150 difference in the two kits, so what's the better deal? They seem to come with the same equipment, although substituting the spacers in the BB for springs in the coil lift. Which is the easier install? Which are people more likely to keep on longer? etc. etc.
Alright, I hope I haven't somehow missed a thread with all these answers, cuz I'd be pretty embarrassed, but I don't think I have. If there's something I leaving out here, please fill me in!
Thanks guys! Unleash the brains!!
Old Mar 17, 2009 | 08:05 AM
ranwitscissorz's Avatar
If you have a rubi and want the best that you can get from the 2.5 kit, get the coil with shock adapters. Spacers give you lift, but not ride quality, coils will give you that, plus it's not recommended to stack spacers like you mentioned doing with 2.5+ .5. The rubi shocks are comparable to the teraflex shocks, so just get extensions to make the length match.
Also, it sit's pretty level with 2.5 coils, I doubt you will need the extra spacer.
Old Mar 17, 2009 | 08:06 AM
TeraFlex's Avatar
Sponsoring Manufacturer
Good advice, saved me some typing.
Old Mar 17, 2009 | 08:11 AM
joey2times's Avatar
ok I can add questiosn to this then... I am waiting for your 2.5'' coils with shocks kit...
Should I just get the extensions, and save $$ on shocks because the TF shocks are not really better ??
I am trying to save some $$ too but I also want a solid rig.
Old Mar 17, 2009 | 08:22 AM
RedneckJeep's Avatar
If you get the spacers, you'll always wonder what the coils wouldda done. Get the coils.
Old Mar 17, 2009 | 08:45 AM
TeraFlex's Avatar
If you have a Rubi, I'd suggest the kit with extentsions #1352000.
Old Mar 17, 2009 | 08:47 AM
greenamphibious's Avatar
Originally Posted by benmar2000
Mine sits really good with the TF 2.5in Coils.. But I also have the TF shocks also..
good now I know I don't need a puck up front until I put a new bumper and winch on... looks good
Old Mar 17, 2009 | 08:52 AM
RescueGreen#3's Avatar
Joe... Does this hold true with a Sahara Unlimited with the factory tow package too?
Just curious because it comes up often. (according to Jeep engineers the oem tow pkg has beefier spring rates & shocks)
Old Mar 17, 2009 | 09:31 AM
If they are red, get shock extensions, if they are black, get replacement shocks.
Old Mar 17, 2009 | 09:45 AM
TeraFlex's Avatar
Correct!
