Stock JK Springs and Shocks on a TJ
Old Mar 17, 2009 | 06:54 PM
kbmk1023's Avatar
Default Stock JK Springs and Shocks on a TJ
Does anyone know if stock JK springs and shocks will fit a TJ?
Thanks in advance,
Brandi
Old Mar 18, 2009 | 05:04 AM
Littlejon's Avatar
The front sripngs will work, but you would lose about 1" in the front compared to the stock front TJ springs. I am basing this off the fact that I gained 1" in the front from the TJ springs when installed in the JK.
Old Mar 18, 2009 | 11:09 AM
HarryHood1's Avatar
i had no idea that TJ springs worked on a JK. if this is true you can find alot of 3.5" up for sale on different forums from people upgrading
Old Mar 18, 2009 | 12:28 PM
White Widow's Avatar
remember that the jk weighs a lot more then a tj. not sure if it matters much though
Old Mar 18, 2009 | 04:23 PM
Littlejon's Avatar
The TJ had a heavier engine and so their springs in the front are designed for the extra weight. They aren't any taller, but the heavier springs will more than compensate for the added weight of a bumper and winch.
