Help...I noticed I'm missing some parts
Old Mar 18, 2009 | 02:45 PM
joneszj's Avatar
Default Help...I noticed I'm missing some parts
I purchased my 4" Superlift a few weeks back from a friend of mine used...
Going through my lift and realized I am missing a rear track bar brace to go with the bracket, so I ordered it, no problems...BUT, I started to check my other parts in the kit.
What is a "compression travel pad spacer???" Is this a fancy way of saying bumpstops or am I way off? I guess I'm so confused because when Superlift listed these parts, there are a bunch of bolts, nuts, washers, etc. to go with them.
Here's a picture of all the random parts I have.
(plus shocks, springs, and disconnects)
A list of the parts can be seen here --> http://www.superlift.com/instructions/5704.pdf
Does anyone have pictures of Superlift part # 55-15-5704 and #66-27-5707? (These are the part numbers for the front and rear compression travel pad spacer)
I am pretty new to lifting, etc. but want to make sure everything I need is here. Thanks for the help.
Last edited by Robar; Mar 18, 2009 at 03:09 PM. Reason: PLEASE DO NOT POST DIRECT NON SPONSOR LINKS
Old Mar 18, 2009 | 02:48 PM
bigbluejk's Avatar
I think that is tho silver things under your bumpstops in the photo. See those washers that are not complete circles? Do yourself a favor and throw those and that bolts that go with them in the trash and get some teraflex adj. front lower control arms.
Old Mar 18, 2009 | 02:59 PM
joneszj's Avatar
Already got em... theres no way I was running cam bolts. But as far as the compression dampers. I have 2, there should be 4 correct?
Old Mar 18, 2009 | 03:11 PM
nthinuf's Avatar
Looks like you have front and rear upper bumpstops, but only one set of lowers. (think those are the front lowers?) Flex it after the install and see if you even need the rear lowers.
Old Mar 18, 2009 | 03:29 PM
BlackNorthernJK's Avatar
providing you have the front adjustable trac bar and springs it looks complete to me. You have all the parts you need from what I can see, you only need two compression stops which...yes, are those aluminum pucks you have, and they go on the front spring mounts....toss those cam bolts
Old Mar 18, 2009 | 03:37 PM
joneszj's Avatar
Awesome, so everything should be fine??? I was just a little confused because the instructions list front and rear compression dampers. I assumed thats what those aluminum pucks were because there is a picture in the instructions of how they fit into the lower coil seat, but no pics of the rears. It does say to replace the rears, but it should be fine with just the stock dampers, right?
Old Mar 18, 2009 | 03:41 PM
joneszj's Avatar
Heres the exact listing from the instructions:
55-15-5704 .................. (2) compression travel pad spacer, rear .......... (4) 5/16" x 3/4" bolt (4) 5/16" SAE washer, (4) 5-16" Stover nut
66-27-5707 ................. (2) compression travel pad spacer, front........... (2) 5/16” x 1-3/4” self-tapping bolt
Old Mar 18, 2009 | 03:42 PM
JKMoses's Avatar
I have the Superlift 4”. I am sending you 4 picīs of part # 55 15 5704 and one of the other part.
Part (2) # 66 27 5707 are the metallic cylindrical shape pieces on the bottom right of your picture.
But I think you missing some parts of your kit.
Old Mar 18, 2009 | 04:02 PM
JKMoses's Avatar
Picture (attached) that I downloaded from Superlift website shows four cylindrical shape dampers, but when I received the kit the printed instructions showed different rear dampers and those were mounted by two screws.
Sorry, I just read your note below your picture; okay your kit is complete except for rear dampers.
Old Mar 18, 2009 | 04:03 PM
joneszj's Avatar
So at the very least, I think I'm missing 55 15 5704 and the associated hardware...hopefully thats all I need, but thanks for the pics, that cleared up a lot
What "some parts" do you think aren't there??? I think I have the rest, but now you have me nervous...
