To wheel space or not to wheel space...
I'm putting on an RC 2.5" coil lift with shocks, longer front & rear sway bar links, rear track bar bracket, break line bracket extensions and front adj. trackbar. I'm running stock 16's with 265/75's (for now) and was wondering with that tire size if I would need wheel spacers. I know going larger I probably would. Anybody else doing this setup without wheel spacers? I don't want to wait til I get new wheels and tires to get this lift on!
I am running 265/75's also. I don't have spacers, but I did change to 16x8 wheels with 4.25" BS, instead of the stock 6.7 or something that the stock 16's have. And I didn't rub before, and now I do :/ In the future, if you go to 12.50's then you definitely will. Mine almost rubbed at full lock with the stock wheels. Now it doesnt rub there. But the front and rear will rub the flares.
Would it help if I mounted the rear sway bars on the inside? If not, could I hold off installing the new sway bars all together? Just use stock? It's basically my DD. Or maybe just get longer ones for the front. Are the stock rear sway bars long enough for my purpose?
Wheel spacers (such as Spidertrax or Teraflex) are safe and economical, if installed and maintained correctly. I was hesitant at first to use them, but they worked out great for me.
I had this problem too with a OME HD lift on frt. and rear. I lenghten the rear sway bar links and wat to close to the rim. They touched the wheel weights. So I got the 1.5 spidertrax spaces and problem solved.
