Steel wheels
Old Mar 21, 2009 | 10:40 AM
jeeperjkj's Avatar
Default Steel wheels
Would these work with 35x1250's or would I need a 1.5" spacer? I think I'll need the spacer, too, but not sure.
Anyone else runnin' them?
http://www.quadratec.com/products/92702_106.htm
Old Mar 21, 2009 | 10:52 AM
geebee's Avatar
i run those with 32s. no spacer.
Old Mar 21, 2009 | 10:57 AM
jeeperjkj's Avatar
Got any pics?
Old Mar 21, 2009 | 11:03 AM
geebee's Avatar
still looking for a center cap solution.
Old Mar 21, 2009 | 11:05 AM
jeeperjkj's Avatar
Not bad. I like the simplistic look.
Old Mar 21, 2009 | 11:10 AM
geebee's Avatar
the only knock i have is that they are more prone to scratches on the trail than the stock moabs....and more noticable because of colour.
Old Mar 21, 2009 | 12:58 PM
yellow07x's Avatar
How about the caps off the 16" steel wheels painted black?
Old Mar 21, 2009 | 02:46 PM
JK-KJ's Avatar
Just a thought....
You could get some Cragar Soft 8's for less money and wouldn't have to worry about rubbing because the backspacing would be correct....not to mention they would look alot better.
Old Mar 21, 2009 | 06:39 PM
jkJason's Avatar
I wouldn't run 35x12.5 tires on these rims, they are only 7.5 inches wide. Check the manufacturer's web site for recommended rim sizes for whichever brand tire you are looking to run. I can almost guarantee any 35x12.5 tire is going to require at least an 8 inch rim width. I am looking at getting the cragar soft 8's in the 17x9 to run my 35'' km2's. Also it seems kind of silly to buy new rims without the proper backspacing. Spacers make incorrect backspaced rims work but ideally you don't want to have to use them... It'll just be one more thing to maintain.
Old Mar 22, 2009 | 02:33 AM
pearl-drum-man's Avatar
You'll probably need spacers, those are pretty close to the stock 17" JK wheel size (17 X 7.5, and 44.45mm offset). As for the width, probably a good idea to check the tire manufacturer's recommendations, however there are a lot of JKers running 35's (and even some 37s) on the stock Moabs (7.5" width). Personally if I were going for new wheels/bigger tires I'd go 8" wide (I'd also go 16", but O/T).
