who makes front tracbar drop bracket
Old Mar 22, 2009 | 03:51 AM
roguejk's Avatar
Default who makes front tracbar drop bracket
who makes a front trac bar drop bracket (frame ) and pitman arm so i can bring my drag link and trac bar as clode to paralell as possible..... i cannot use the teraflex draglink flip kit since i no longer have the stock drag link and their unit uses the factory adjuster sleeve.....i need this since i do have 4" of lift or slightly more......thanx guys , any help is greatly appreciated !
Old Mar 22, 2009 | 05:52 AM
bOLsAK=3's Avatar
I believe I've seen one from Rancho.
Old Mar 22, 2009 | 06:08 AM
Robar's Avatar
I am using a Full Traction frame mounted drop bracket and what ever kind of drop pitman arm David, Northridge4x4, sent me. The drop bracket is a stout piece of metal.
Sorry, the bracket is a little blurry, but you can see my tire tread quite clearly.
Old Mar 22, 2009 | 07:30 AM
wayoflife's Avatar
JK-Forum Founder
as mentioned, full tration makes a great drop bracket from the frame and pretty much all the dropped pitman arms are made by the same company. the rancho setup is the only one that i know of that is different and it is about an inch longer than the rest (4" instead of 3"). also, for whatever it's worth, the teraflex track bar drop bracket can still be used if you wanted and it comes with an additional weld on brace. the drag link flip kit is a separate piece and you do not need to install it. you can always install a dropped pitman arm instead.
Old Mar 22, 2009 | 11:40 PM
roguejk's Avatar
Thanx for the help, I guess I'll give dave a call @ northridge and I'll just have to choose between The two. The brace your refering to, is it a sector shaft brace?
I'm looking to beef up the entire front end Wd much as possible, you know the d30 gussets n stuff as well as steering components.... Thanx for the input guys
Old Mar 23, 2009 | 02:47 AM
roguejk's Avatar
Hey robar, I also have the JKS discos and was wondering if at the bottom yours angle out some ? Cause mine does... Just wondering if it's normal...
Old Mar 23, 2009 | 04:21 AM
Robar's Avatar
They do, but only slightly. Maybe a 1/4 to 1/2" difference from top to bottom.
