Yet Another Trackbar/Control Arm ?
Old Mar 24, 2009 | 11:48 AM
ejb17's Avatar
Exclamation Yet Another Trackbar/Control Arm ?
Sorry if everyone has to repeat themselves but there is too much info on the site that my head can not wrap itself aruond it all. So here goes-I put in the RC 2.5 coil lift with 2.2 shocks, ProComp 17" wheels and 285/70 BFG All-Terrains, and the RC dual stabilizer. Everything is great except I now notice that the steering feels a little light even though I have been playing with the air pressures. I know the caster is a little light and the axles are not perfectly centered. What would you guys do and whose products would you use? I like the looks of the TF stuff and also JKS. Also, is there any caster adjustment at all on the stock arms? I refuse to do the cambolt/oblong the holes crap. Adjustable trackbars or frame bracket pros/cons would help me also because I remember reading something about roll center issues. Again sorry for being long winded but the wife and son use this vehicle too and I do not want any issues. I have checked all torques on trackbars and control arms,etc to avoid the DW. Thanks
Old Mar 24, 2009 | 11:50 AM
wayoflife's Avatar
JK-Forum Founder
you might want to add a 1/16" more toe but ultimately, flighty steering is a caster issue. installing a set of adjustable lower control arms and lenghtening them a bit to give you more positive caster will help out a lot.
Old Mar 24, 2009 | 12:21 PM
bigbluejk's Avatar
You would be amazed how nice it will drive if you throw on some adj. lower front arms like WOL said. It will be a sportscar compaired to the way it drives now.
Old Mar 24, 2009 | 05:40 PM
NH4X4's Avatar
Default track bar
If you r looking 4 a track bar... i just put a Rustys Off Road 3.25 lift in my 2007 and it came with verry nice front and rear track bars. Verry Beafy
Old Mar 24, 2009 | 05:44 PM
bigbluejk's Avatar
those uppers are the exception I think, as most will NOT get short enough to adjust caster. That is a good way to increase caster if you want to use them IMO. If you feel a lower like teraflex or FT you will want that scraping across rocks instead of the dinky factory arms I bet.
Old Mar 24, 2009 | 05:45 PM
wayoflife's Avatar
JK-Forum Founder
Originally Posted by MB-08-JK(R)
How about adjustable upper control arms as an alternative. Per David at Northridge Currie has some arms that will adjust short enough to increase your caster without lengthening your wheelbase.
yup, the currie upper arms will do the trick
Old Mar 26, 2009 | 06:53 AM
ejb17's Avatar
So besides the Curries would you guys suggest TF's trackbars and arms,JKS or anyone else?
Old Mar 26, 2009 | 06:57 AM
wayoflife's Avatar
JK-Forum Founder
sure. those are all good manufacturers. the currie front uppers are just the only ones that i know of that can be shortend enough to give you sufficient positive caster is all. but, you can always add more positive caster with adjustable lowers too.
Old Mar 26, 2009 | 07:59 AM
RedneckJeep's Avatar
But as you lift the Jeep, the axles follow an arc that lends them to shorten the wheelbase. Wouldn't the longer adjusted lower arms correct for this?
Old Mar 27, 2009 | 04:52 AM
ejb17's Avatar
So last night I measured the caster on both sides up front with a digital angle finder. The left side bounced between 3.7 and 3.8. The right side was 3.7. I now know that it is for sure a little light and was wondering what spec is and if I should go a little more because of the bigger tires? I am still deciding whose arms and front track to buy. I have decided on the TF rear trackbar bracket for the axle housing. Any other thoughts are appreciated.
