RPM with gear change
What RPM are you turning at 60MPH with 4.88 gears and 35s? I'm turning 2500 RPM. I have the six speed transmission. I was turning 1900 RPM at 60MPH with the X stock tires.
I assume your asking because it seems high. I just had 4.88 put in and I run 35's too. I havn't done the math yet, I would rather just ignore the 10mpg average Im sure I will see after the first fill up. Wondering if I should of went 4.56. Oh well there in.
Same RPM as you.
Same RPM as you.
Actually, I wouldn't have gone less. The anemic 3.8 needs all the help that it can get. I was just curious because in order for my programmer to indicate the right speed I had to enter my tire size as 33.
you have some type of stroker kit or something
