about to replace stock Rubi coils with OME 'Standard' Duty
Old Mar 26, 2009 | 04:11 PM
Jeepin_D's Avatar
Default about to replace stock Rubi coils with OME 'Standard' Duty
I have a 4 DR Rubi -- only mod I originally made was a 2' BB to cut down on skid plate abuse. I'm more into overlanding than rock crawling.
After adding front/rear Mopar bumpers, front skid, winch + tire carrier, stock coils are getting taxed and starting to bow out a bit at the base, with only about an inch of upward travel before contacting the bumpstops.
So, with my desire for minimal lift of only 1-2", but enough stiffness to handle the added weight, I ordered the OME 616/617 'Standard/Light' duty coils and will be de-installing the BB and going back to stock + those coils.
I haven't seen anybody do that yet, just new coils with stock shocks and such, so we'll see how it turns out.
Thanks to David and Marc @ OME for answering all my ?'s.
D
Old Mar 27, 2009 | 03:24 AM
azeeb's Avatar
Show pics and measurements when you are done.
What color is your jeep? I'll keep an eye out for ya. I'm in Williston.
Old Mar 27, 2009 | 04:42 AM
Jeepin_D's Avatar
Will do. I have measurements before and after bumper installs with the BB.
It's Red Rock.
D
Old Apr 14, 2009 | 04:10 PM
Jeepin_D's Avatar
OK, so springs are swapped. Pulled the stock Rubi Unlimited springs and replaced with OME 616/617 'Standard' duty springs. My goal was slight 1-2" lift, simiilar factory travel, AFTER install of heavy steel Front/Rear bumpers + winch + tire carrier.
Here's how the measurements played out:
Stock:
Didn't measure
With Superlift 2.5" BB, front Mopar Skid, after about 4K miles:
Left Front = 36 7/8"
Left Rock Rail = 19 1/2"
Left Rear = 38"
WIth Superlift above, AFTER install of Mopar Front + Winch, Mopar Rear + Tire:
Front Left = 36 6/8"
Left Rock Rail = 19 1/4"
Left Rear = 37 3/4"
Removal of BB, swap of stock springs with OME 616/617:
Front Left = 37 3/8"
Left Rear = 37 1/4"
Top Front Bumper = 29"
Top Rear Bumper = 29 3/4"
Front Left Rock Rail = 19 3/8"
Rear Left Rock Rail = 19 1/2"
Measurements on Front/Rear were through center of wheel to bottom lip of fender flare. Rock rail measurements were at hinges on rear doors unless otherwise noted.
Right side measurements are almost all 1/4" lower than the left (seems standard on JK's to lean right a little due to fuel tank or whatever).
So, bottom line, I got what I was looking for. Front actually ended up higher than the original BB, before bumpers, by almost 1/2". Rear ended up about 3/4" lower actually than the BB, but by doing so most of the factory rake was eliminated, which is a plus for me (so far anyways, jury is out on that).
Overall ride seems a little stiffer actually, which surprised me a bit based on posts on this forum. Need to drive it more to see if that changes.
If you're looking for something just a little higher than stock after addition of heavy bumpers, this seems like a good option to me.
D
