Dirty Heim Joints
So I took off my wheel today and noticed that my heim joints on my Currie control arms were a little dirty:
You can see all the dirt down inside the joint. Is this OK? I grease them about once a month or so, is there any other maintenance I should do to them? I know they are rebuildable if you have to buy a kit, but I'm not sure if I can take them apart and clean them without a kit.... Thanks!
what robar said. you do not need to pull your joints apart as the new grease will push out any contaminants and keep things clean inside.
