winch on stock bumper
Old Mar 26, 2009 | 05:41 PM
jeffnesom's Avatar
Default winch on stock bumper
does anyone know if you can get a winch mount for a stock front bumper that will not require cutting the bumper
Old Mar 26, 2009 | 11:31 PM
cfr's Avatar
cfr
Rough Country makes one for ~$249 which I've been looking at about. That's getting close in price to to winch-mount replacement bumpers though.
Old Mar 27, 2009 | 08:26 AM
Lanster's Avatar
most winch mounts are going to require some amount of cutting to the bumper or the mount to get it to fit.
Old Mar 27, 2009 | 01:29 PM
cfr's Avatar
cfr
I've never installed this, but looking at the installation instructions,
www.roughcountry.com/install/1173.pdf
it appears that you only have to cut anything if you don't have the factory tow hooks.
Old Mar 28, 2009 | 07:09 AM
schwarzjp's Avatar
WARN makes a winch plate for the stock JK front bumper than doesn't involve any cutting. It's expensive though.
Old Apr 18, 2009 | 05:59 AM
Heyspike's Avatar
I was looking at the winch mount for that and have a couple of ???'s.
I just installed a Curtis front hitch and I believe it uses the same holes on the frame rails to mount the winch.
The hitch had about a 1/4 " play side to side inside the frame rails, I was thinking if the winch plate was a tight fit, I could shoehorn the plate and the hitch into the same holes. How was the fit of that plate?
Thanks.
