New Gears and the Speedometer?
nope... unlike the old TJs where they read speed from a speedo gear in the transfer case, these get the speed from the ABS tone ring I think. So the speedo is only affected by tire size. No more cheap $8 speedo gears to re-calibrate speed. :( o well.
That's an excellent question?? As I understood the wheel sensor is on the front driver side wheel...so I'm not sure if gear change affects speed?? The Hypertech programmer I have is simply a speedo recalibrator and it has tire size and gear ratio in it....someone else
