Toyo OC M/t 35x13.5xR15 question
Will these 35x13.5xR15 fit on 15x8 Cragar steel rims? I'm about to pull the trigger on some Toyo's and want to make sure I can do the 13.5 or else I'll do the 12.5.
Thanks for any input
Yes in the sense that you are moving the tire farther away from the axle, due to the added width over stock. The offset of the wheel will also have to be less to accomidate the wider tire. The pressure will stress the unit bearing, balljoints, c's, and tubes. Is it a serious concern? Some would say yes, i've been running mine for over a year, no problems.
