Black Diamond 3" Lift--will I need a Driveshaft Replacement?
Old Mar 31, 2009 | 12:54 PM
sm_rubi's Avatar
Default Black Diamond 3" Lift--will I need a Driveshaft Replacement?
I have an automatic 4 DR Rubicon with a 3" Black Diamond lift. I have been reading a lot about 3"+ lifts and torn drive shaft boots. I did a thorough search and have not found anyone with this specific issue that had the 3" BD lift. Am I looking at an eventual front drive shaft replacement with this lift? So far have only had the lift for about 700 miles and did take it off road a couple times...disconnected the sway bars, but no major flexing as of yet (but very possible in the future).
Old Mar 31, 2009 | 02:07 PM
Calypso's Avatar
You should be fine. If you were to have any rubbing it will be at full, disco flex and it will be your ds on your transmission skid, but I doubt you will. I have your set up with a 2 1/2" (which actually gave me 3 1/4") and I haven't had any problems, even at full flex.
Old Mar 31, 2009 | 02:19 PM
vogeljk's Avatar
Default You will need a driveshaft replacement for the front
I have a TF 3" Lift with an auto and had the stock driveshaft still on. I wheeled, did some flexing (still connected) and tore up my boot. It is only a matter of time before you tear yours up. I took mine to a local reputable driveline builder and he built me a heavy duty dl for the front and installed it and warranted it for $350.
Old Mar 31, 2009 | 02:29 PM
Calypso's Avatar
What was your actual lift height?
Old Mar 31, 2009 | 02:40 PM
dpoelstra's Avatar
I have the Black Diamond 3 inch springs which gave me a full 4 inches of measured lift, and after 20k miles have settles to about 3 1/2 inches.
I ripped my front boot on a rock ledge, but it had nothingto do with the lift. You should be fine.
Old Mar 31, 2009 | 03:06 PM
Calypso's Avatar
It really depends on the actual height gained. I think Vogeljk probably ended up with around 4" with his TF 3" kit.
Old Mar 31, 2009 | 03:15 PM
sm_rubi's Avatar
Thanks everyone for the input.
Haven't measured the actual amount of lift but from what I understand the BD lift's the front a little over 4" keeping it at 3" in the middle.
I guess we'll just have to keep an eye on it and hope we are lucky and it holds out...but if not, I like the idea of having one built like vogeljk did.
Old Mar 31, 2009 | 03:21 PM
zook's Avatar
I have the 3" BDS lift and no problems. You shoul be fine.
Old Mar 31, 2009 | 04:16 PM
BlackNorthernJK's Avatar
My Black Diamond 3" also netted closer to 4"s...something to consider
Old Mar 31, 2009 | 04:27 PM
AlmightyCrash's Avatar
I have the 3"BD, and tore my boot.
i run it pretty rough sometimes though.
I see that boot torn fairly often on JKs.
I still love my lift though...it comes with tons of parts to correct changes from lift.
