painting xenon flares ?
Old Apr 3, 2009 | 09:12 AM
blockrockin's Avatar
Default painting xenon flares ?
hey, im going to paint my new set of xenon flares. just wondering what kind of prep work i should do . they are really smooth and kind of oily. i figure i would try to find some primmer for plastic .. any one have any suggestions ? thanks alote .
Old Apr 3, 2009 | 09:20 AM
john smack's Avatar
Try and get all the oily substance off apply a coupl coats of primer and sand the primer a bit so the paint will take a good hold and apply 3 coats of color
Old Apr 3, 2009 | 09:29 AM
thanks would acetone work ok to remove the oil. or would it eat into the urathane , i think thats what they are made of ? also should i sand the flares before i prime them?
Old Apr 3, 2009 | 09:40 AM
john smack's Avatar
I dont know you should go to a paint store to see what they reccomend for removing film on the plastic and I dont think it would hurt to scupp the plastic even with a mild 3M pad before primer
Old Apr 3, 2009 | 10:13 AM
thunderstrike44's Avatar
Default Flexiable Painting
I am not the expert but my brother-in-law painted my other Jeep and has painted cars for 27 years. I had asked him this very question before and I have a set of Xenons on my YJ. He told me that I would have to buy an additive for the paint I want to use so it would stay flexible and allow the flares to bend without cracking or spiderwebing the paint...within limits. Most Urethane covers on modern cars have this additive put in the paint . It can be added to most 2 part paints. You would have to ask for it at a auto paint store, I don't think you are going to find it at pep boys. I hope this helps you out.
Old Apr 3, 2009 | 11:00 AM
STUPIDFACE's Avatar
Im no expert either, but if it were me, i would use some MEK to clean off the oily stuff. I know exactly the oily stuff your talking about. I would then rough it up with some 660 or so grit sand paper. Then i would wipe it off again with MEK. The MEK evaporates real fast and doesnt leave any residue. Then paint it. Rough it up with 600 grit and wipe it down with MEK between coats (if your painting it, not if your bedlining it). If your using that duplicolor spray bedliner, i would just let it dry for about 5 min. between coats (no sanding).
Disclaimer: Im a dummy!!!
corey d
Old Apr 3, 2009 | 12:13 PM
great thanks for everyones repleys... that helps alote... maybe i will just line -x them again.. i liked the other ones that i line-xd.. just thought maybe i would paint part or all of these rescue green.. thanks for the help
