Sway bar end links...NEED HELP!
It is my understanding that the rear sway bar should be parallel to the ground, or "0 degrees"...Is this correct ?
It is also my understanding that the front sway bar should be at 5 degrees...Is that 5 degrees down towards the ground? or 5 degrees up towards the Jeep?
Do each of the front sway bar end links need to be the exact same length ?
Do each of the rear sway bar end links need to be the exact same length?
I have already installed the OME HD Long travel kit from David at Northridge, but I just received the adjustable sway bar end links.
I have a 2008 2dr Rubicon 6spd.
If anyone can help it would be much appreciated! Thanks!
Some adj the rear right a little longer to compensate for the JK lean. The front should be the same length.
https://www.jk-forum.com/forums/show...highlight=lean
Well, no, I don't understand it as it seems the sway bar would flex more to compensate for the different lenghs. But. WOL says it does in this link:
I still need to know if the rear should be at 0 degrees, or parallel to the ground? AND
Is the front to be at 5 degrees ? and, is that 5 degrees down toward the ground? or 5 degrees up toward the Jeep?
Anyone....?
The front should be set to 0 degrees with plus or minus 5 degrees being within tolerance. The rear should also be at 0 degrees but it is not as critical as the front as long as you are close to level.
I installed Currie adj on the rear and set my right one about 1/2" longer, just at WOL mentioned. It does work, I would think that the sway bar would just flex to account for the different sway bar links but my JK doesn't lean anymore.
