JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
48 v 60Hilift
Old Apr 12, 2009 | 06:13 AM
nuclrhorseradish's Avatar
Default 48 v 60Hilift
Hey all,
Im going to pick up a hilift as I build out my recovery kit. Im thinking it wise to just grab a 60 inch jack instead of the 48 for the extra 15 bucks.
Does anyone have some pros/cons about the 48 versus the 60 or is this a personal preference thing?
Thanks,
--Josh
Old Apr 12, 2009 | 06:25 AM
Offroadme's Avatar
this was just covered a few days ago same post if you search you can prob find it.
some people said they liked the 48 because it's easier to store less bulky. but other than that there is really no difference as far as im concerned. also depends on what kind of lift you are going with
Old Apr 12, 2009 | 06:30 AM
Hmm couldnt find an earlier post even with a 'hilift' search.. oh well. Next time.
Just installed a 3" BDS suspension lift, which actually netted about 4 inches. (kinda funny - got more lift and the 32s look like pizza cutters now lol ) When the dough comes in I will move to 35s instead of the 32s I have now - I cant imagine that even with the 35s I would *need* the 60 for anything...
Old Apr 12, 2009 | 01:00 PM
Muffins's Avatar
if you already have a 48" can you get the longer "pole" if you need a longer jack? (Not sure what you call the main beam for the jack)
Old Apr 12, 2009 | 01:15 PM
westchester's Avatar
Originally Posted by nuclrhorseradish
Hey all,
Thanks,
--Josh
Bigger is usually better in most apps, especially if you're also using the hi-lift as a manual winch. The 48 can be mounted in many places on a Jeep. The only safe place I found for the 60" is mounted vertically on the rear bumper.
Old Apr 13, 2009 | 06:33 AM
jkkat's Avatar
60" hilift is really hard to mount some place without it getting in the way.
I use my 48" and a ratchet strap between the axle and frame to keep the suspension from dropping out.
Old Apr 16, 2009 | 11:11 PM
chuck45's Avatar
I've got a 60" and recommend it highly. Harder to mount but it is worth it. I've been in situations where the 60 was a couple of inches from being maxed out. Of course part of it depends on what your vehicle is. A stock X and a lifted 4 dr on 37's have different needs.
Old Apr 17, 2009 | 06:57 AM
chuck45's Avatar
Originally Posted by Atrane21
i have a 60" and i love it other than the fact of mounting it on the jeep! i have yet to find a place that i would like to mount where it is out of the way.
i was going to trade mine for a 48" but i've been leaning towards just keeping it.
I mount mine horizontally on the swing out tire carrier. No problem as the Jeep is wider than 60".
Old Apr 17, 2009 | 07:13 AM
Here's the first pic for this thread - DON'T gimme sh&t for the position - I since moved it higher, repositioning the Hi-lift tube bumper brackets, so the 60" jack is now fully above the hitch, and no (less) ground clearance problems.
Old Apr 17, 2009 | 08:31 AM
jkkat's Avatar
If i did that with RubyDoo, it would have been ripped off a long time ago.
