How to get tires to fit?
I am purchasing a 09 4 dr rubicon and am looking at 33x15.5 tires. Realize I will have to get wheels. What size wheels will I need for these to fit. Do I need lift due to the width of the tire (15.5).
Thanks,
Lisa
Thanks,
Lisa
others may chime in here and correct me, but with no lift you will need to find a wheel with 4.5 of backspacing and maybe even add wheel spacers....thats a wide tire....my guess is you will rub your fenders when flexed with no lift added too.
That's a really wide tire and it's going to need a fender trim without a lift. Back spacing is going to be dependent on what width wheel you run, and I can't see running anything less than a 9" wheel width.
That is a really wide tire. I guess your going for the extra wide stance. I think that is a little wide for that tall of a tire. You might run into rubbing problems as well if its not set up right.
While I concur that it might look like ass, there are some pretty functional bias ply balloon type tires which are going to be well rounded at the potential rub points. Not my gig at all as I always need to get blasted with some mud before I roll up the windows, and those tire would be dumping bucket loads in with their first shot at it.
