Top Cargo??
Old Nov 20, 2006 | 05:37 AM
Txhrns08's Avatar
Talking Top Cargo??
OK I really like this Rack shown below.. does any one know, does the rack work when the hard top is on and off? if so how does it remove to allow you to put the top on and off?
ID:	97440   Click image for larger version
ID:	97441   Click image for larger version
Old Nov 20, 2006 | 05:47 AM
wayoflife's Avatar
JK-Forum Founder
This is a Kargo Master Bushman Steel Rack that can be mounted to the roll bars of a Jeep. For the TJ, YJ and CJ, you could by their Congo Cage with attaches to the windshield frame and just above your tail lights and then the basket part you see on top of it. I have this setup for my TJ...
At least for older Jeeps, all you need to do is unbolt the front windshield mounts and tilt the whole thing back for top removal. When Kargo Master comes out with one for the JK, I'd be willing to bet it'll work the same way
ID:	100015   Click image for larger version
Old Nov 20, 2006 | 06:00 AM
Bad Dawg's Avatar
So, would this work with the fold down windshield? I'm guessing the rack would have to be removed/tilted back somehow to allow the windshield to be folded down or back up again. How much weight can the current rack hold?
Old Nov 20, 2006 | 06:16 AM
wayoflife's Avatar
JK-Forum Founder
No, the Congo Cage cannot be used with the windshield down. The only way you can do that is to attach the basket on the roll bars as is shown in the first photo. As far as weight goes, it can safely carry 400 lbs. and I have done it before
ID:	97465   Click image for larger version
ID:	97466   Click image for larger version
Old Nov 20, 2006 | 06:30 AM
Bad Dawg's Avatar
I haven't seen how the JK's windshield attaches. I was guessing that the Congo Cage could attach at the same place using an adapter. Is there a good close-up picture of how the windshield bolts on and off? I don't remember seeing one in the HUGE selection of shots you have ( ).
ID:	97486   Click image for larger version
ID:	97487   Click image for larger version
ID:	97488   Click image for larger version
ID:	97489   Click image for larger version
ID:	115024   Click image for larger version
ID:	115025   Click image for larger version
ID:	124270   Click image for larger version
ID:	163147   Click image for larger version
ID:	163149   Click image for larger version
Old Nov 20, 2006 | 06:42 AM
wayoflife's Avatar
JK-Forum Founder
Because the windshield is curved on the JK, they now have a hinge in the middle as opposed to one on each side of the window frame...
Here is a close up of the windshield brackets that would need to be unbolted prior to dropping it.
ID:	97627   Click image for larger version
Old Nov 20, 2006 | 07:23 AM
Bad Dawg's Avatar
Thank you. Those really help. You wouldn't happen to have a shot of the area that gets unbolted showing the windshield folded down would you? I was wondering what was behind what is shown in the second picture you posted. Is there any structure behind there that could be bolted to or does that part with the six bolts stay in place when the windshield gets folded down?
Name:	JK at Car Wash 2.jpg
ID:	97794   Click image for larger version
Name:	JK at Car Wash 1.jpg
Old Nov 20, 2006 | 07:47 AM
wayoflife's Avatar
JK-Forum Founder
Here, this should help ya out
BTW: If I'm correct, this is jocrazy0 JK
Old Nov 20, 2006 | 07:58 AM
Bad Dawg's Avatar
It looks like the part I asked about is actually removed and the spot it bolted to is still there. I would guess that this spot could be used to bolt a rack to, similar to your older Jeep. I bet someone is looking at doing something like this.
ID:	149   Click image for larger version
Old Nov 20, 2006 | 08:12 AM
wayoflife's Avatar
JK-Forum Founder
Yup, that sounds about right and I bet there is someone out there working on this
ID:	98133   Click image for larger version
ID:	98134   Click image for larger version
ID:	98135   Click image for larger version
ID:	98136   Click image for larger version
ID:	98138   Click image for larger version
ID:	98139   Click image for larger version
ID:	98140   Click image for larger version
ID:	98141   Click image for larger version
ID:	98143   Click image for larger version
ID:	98144   Click image for larger version
ID:	98145   Click image for larger version
ID:	98146   Click image for larger version
ID:	98149   Click image for larger version
ID:	98150   Click image for larger version
ID:	98151   Click image for larger version
ID:	98152   Click image for larger version
ID:	98154   Click image for larger version
ID:	98156   Click image for larger version
ID:	98157   Click image for larger version
ID:	98159   Click image for larger version
ID:	98164   Click image for larger version
ID:	98166   Click image for larger version
ID:	98169   Click image for larger version
ID:	98170   Click image for larger version
ID:	98172   Click image for larger version
ID:	98173   Click image for larger version
ID:	98174   Click image for larger version
ID:	98175   Click image for larger version
ID:	98177   Click image for larger version
ID:	98178   Click image for larger version
ID:	98179   Click image for larger version
ID:	98180   Click image for larger version
ID:	98182   Click image for larger version
ID:	98185   Click image for larger version
ID:	98186   Click image for larger version
ID:	98187   Click image for larger version
ID:	98189   Click image for larger version
ID:	98190   Click image for larger version
ID:	98191   Click image for larger version
ID:	98192   Click image for larger version
ID:	98194   Click image for larger version
ID:	98195   Click image for larger version
ID:	98196   Click image for larger version
ID:	98197   Click image for larger version
