What can stay?
Old Apr 13, 2009 | 07:23 AM
easttnruby's Avatar
Default What can stay?
Im removing my 3" lift from my 4-door and was curious. Can I still use my adj. trac-bars on front and rear instead of stock? Also, I have JE Reel driveshafts. Will these thing still fit when jeep comes down a few inches?
Old Apr 13, 2009 | 07:29 AM
eDiveBuddy's Avatar
If you're going back to stock, the track-bars could be a problem as they might not be short enough. The drive shaft should be fine. Did you throw out your track bars? Why are your removing the lift?
Old Apr 13, 2009 | 09:26 AM
Calypso's Avatar
Yea, why the down grade? I still have my stock track bars.....
Old Apr 13, 2009 | 04:51 PM
rjhoop's Avatar
have to change it all!!!!!!!!
give it to me
Old Apr 13, 2009 | 06:09 PM
joey2times's Avatar
Why are you downgrading ?? and what are you doing with your gear ?? take it all out and I will buy it !!!
Old Apr 14, 2009 | 08:04 AM
easttnruby's Avatar
Now that i have the xenon flares, i kinda want to just run 33's when im not wheelin. I have atotal of 4" in front and 3" in rear. combined with the xenon flares I have way too much room in the fender. And no, i dont want to go to 37's. Would like to keep at least the front trac-bar because I had a custom beefy mount welded to the axle and dont think its same spot as stock.
