Nitto Mud Grapplers PSI
Old Apr 14, 2009 | 04:36 AM
JKJosh's Avatar
Default Nitto Mud Grapplers PSI
Hey everyone-
I just picked up a set of 35 inch mud grapplers off craigslist and was wondering what psi everyone is running in them. They are E rated, so I guess that is why the sidewall is recommending 45 psi. I think this is a little steep, but wanted to check with all of you. Right now it seems a little bouncy. They are 35 12.5 18's.
Thanks
Old Apr 14, 2009 | 05:40 AM
Dunecat's Avatar
I run my 33in Mud Grapplers (same E rating) at 37 psi. They ride a little hard, but I have 32,000 miles on mine and have only lost 3mm out of the original 14mm tread depth with even wear. I also wheel hard 3-4 times a year. Make sure you rotate them every 3-5,000 miles and they will last a good long time.
Old Apr 14, 2009 | 05:43 AM
l3itch's Avatar
I run my 33s at 28psi
Old Apr 14, 2009 | 05:51 AM
l3itch's Avatar
Originally Posted by .:eMETAL:.
Do you mean posting a response or going down a steep hill?
Old Apr 14, 2009 | 06:25 AM
Gaidheal's Avatar
Originally Posted by JKJosh
Hey everyone-
Thanks
I've never seen a recommended pressure on a tire but I've seen a load rating at a maximum pressure. Since the tire maker doesn't know what it will be run on, how could they make a recommendation?
Old Apr 14, 2009 | 06:41 AM
NTXJK's Avatar
13 PSI Offroad 30-35 Daily, it pretty much comes down to comfort and how much wear you want on your tires !
Old Apr 14, 2009 | 07:39 AM
JKJosh's Avatar
both!
anywhooo... JKJosh the link in my last post will bring you to your answers. the sidewall reading is no where near what you should be running... infact its WAY over. by running that psi you should be experiencing a knobby ride... bring your 35s down to 28psi and your ride will smooth right out.
Thanks alot man. I looked for that thread, but couldnt find it. Thanks for all you help.
Old Apr 14, 2009 | 07:48 AM
rjhoop's Avatar
i run my 35s at 30psi...
Old Apr 14, 2009 | 09:25 AM
tgrt's Avatar
Former Vendor
Since I have a PowerPlant it's been convenient for me to play with the tire pressures a bit. For me I've found that 32 PSI is best for ride and mileage.
Old Apr 14, 2009 | 09:34 AM
JKsJK's Avatar
35x18 here - generally 32 on and 15-18 off.
