D-ring ideas
Old Apr 14, 2009 | 02:32 PM
JKFive-O's Avatar
Default D-ring ideas
Do you guys think I can mount a set of D-rings while keeping my stock bumpers? I'm wondering if I can mount them to the steel underframe and cut the plastic bumper to have them exposed. What ya's think?
PS: save your breath on the "Just get steel bumpers" remarks. Eventually I will
Old Apr 14, 2009 | 02:33 PM
greenamphibious's Avatar
I'm sure you could. You would want to anchor it somehow like where the recovery hooks are. if you just bolt them to th esteel bumper you will be getting that bumper you don't want to hear about
Old Apr 14, 2009 | 02:35 PM
AZJeeper's Avatar
Community Favorite
The rear would be relatively easy, but what about the crush cans up front? The point you would need to attach to is behind the cans. Most after-market bumpers get rid of the cans anyway, so maybe that's an option.
Old Apr 14, 2009 | 02:43 PM
JKFive-O's Avatar
I think I coughed up my stuffed shells reading that... too damn funny I could picture that happening. Is there much space between the plastic and the steel on the front bumper because of the crush cans? Maybe I cuold make a bracket to mount the D-ring onto.
Old Apr 14, 2009 | 07:31 PM
socal4dr's Avatar
YO i am about to do this same project the only reason for delay is that the way im thinking looks too much like a h3 im thinkin of puttin 2 up front and 2 in the rear. ima try to bolt the drings and the plate to where the tow hooks on the front bolt in. for the back im not sure can someone post a picture of the rear without the bumper.
also if anyone sees that post link it to this one i think it had some pics in it
W
Old Apr 14, 2009 | 07:38 PM
davidwm71's Avatar
get in touch with me... I'd like to get involved with some modifications like that. I have a friend who owns a fabrication shop and I'm sure he could help suggest something.
Old Apr 14, 2009 | 07:43 PM
RedneckJeep's Avatar
It would be tough to do in the front. The Pure Jeep d-ring mounts have the same bolt pattern as the front bumper mounting holes. Your problem as stated above will be the crush cans. The mounting points for the d-rings are probably like 6" or so BEHIND the plastic front bumper. This would put the d-rings in a deep hole in the bumper. What I would do if I were you would be to just remove the crappy plastic bumper cover, and leave the bumper frame on and use it for your bumper. Of course you'd need to cut the crush cans off to still mount the d-rings. Since they bolt to the frame ends, they would still be good recovery points.
Old Apr 14, 2009 | 08:00 PM
JayhawkJeep's Avatar
Veteran: Navy
I cut the plastic off my bumper and the crush cans came off very easily with a grinder. Just make sure you do a good job welding that on, the metal underneath the plastic shell is generally only 1/8" in most places.
Old Apr 14, 2009 | 08:03 PM
He doesn't have to weld at all. The mounting points for the bumper are extremely stout, as they are the frame ends. The Pure Jeep d-rings are designed to bolt right to the frame end brackets with no modification other than perhaps knocking out the factory bumper mounting bolts. Those mounting points on the frame ends are WAY more than 1/8" thick. The bumper frame however, is another story.
Old Apr 14, 2009 | 08:19 PM
JKFive-O's Avatar
All very good points, guys. Dave, I'm thinking there has got to be a way to shape a sturdy extension bracket that can move the D-ring close enough forward. I also haven't looked closely enough at pics of front bumper removed.
