Hood Vents
Old Apr 16, 2009 | 03:04 PM
JK Dawg's Avatar
Default Hood Vents
Has anyone added vents to their hood? It seems this would improve airflow for increased cooling and reduce or eliminate the dreaded hood lift, since incoming air would have an escape.
I had drilled six 3" holes in my XJ (three per side in a line) and covered them with two reversed hood scoops for protection from the elements. This made an amazing difference in on & off road temps.
Your thoughts how this would work an a JK?
Old Apr 16, 2009 | 03:56 PM
seer1's Avatar
These things run hotter'n hell from the git-go. Then add on some skids which traps even more heat in, hit a 10,000 foot mountain pass trying to keep up with traffic while carrying a boatload of gear and well.... I have a transmission cooler half hooked up and a set of Gen-Right hood louvers sitting in the garage waiting for me to get caught up on some other projects. There'll be picts when it's done.
Of course instead of cutting holes for louvers, you could spring the $750 for an AEV hood.
Old Apr 16, 2009 | 04:29 PM
nangulator's Avatar
They would just let more water into my engine compartment.
Old Apr 16, 2009 | 05:26 PM
greenamphibious's Avatar
hood bounce = remove the spring for free
cooling.... eh, doubt you are gonna cool it much more with little vents. I do like the AEV hood
Old Apr 16, 2009 | 07:41 PM
seer1's Avatar
Is that Drowningtown you're from?
Old Apr 16, 2009 | 07:43 PM
07Rubi2dr's Avatar
River raider makes a set I think I'm going to get
Old Apr 16, 2009 | 07:53 PM
moabjk072d's Avatar
Default Hood vents
I put hood vents in my hood and I noticed a big difference in engine temps and they look cool to.
Old Apr 16, 2009 | 08:21 PM
nangulator's Avatar
No, I just like spending time in the Pine Barrens, The actual town of Downingtown was built on a dried up lake bed and does flood every now and again
Old Apr 17, 2009 | 06:21 PM
JK Dawg's Avatar
That's why I covered them with the reverse hood scoops. Worked well on my Cherokee.
Old Apr 17, 2009 | 07:08 PM
JKrJohn's Avatar
See thread https://www.jk-forum.com/forums/modified-jk-tech-2/cut-hood-installed-vents-39508/
It was an absolute must with the AiROCK system IMO -- way too much heat under the hood before the vents. MUCH improved in heat reduction, as it no longer vaporizes the oil in the York compressor.
I never installed rain diverters either as I figured it was a waste of time for little concern... and haven't had a problem to this day.
I say go for it, save the $700 on the AEV hood, and add a true custom mod. Happy cutting!
I also thought it would eliminate the hood lift with spring removed, but it only reduced it.
