Will the 2.5" Teraflex coil lift work with e-disc swaybars?
Old Apr 17, 2009 | 09:44 PM
silvel2edge's Avatar
Default Will the 2.5" Teraflex coil lift work with e-disc swaybars?
Will my electronic disconnecting swaybars still work with the 2.5" Teraflex coil lift?
Old Apr 18, 2009 | 12:27 AM
armycop's Avatar
Yes, but make sure you put the rear swaybar link on the front, and longer links on the back. If you use the short links up front, it may cause the swaybar to flip. The swaybar should be parallel to the ground looking at it from the side.
Old Apr 18, 2009 | 02:05 AM
bOLsAK=3's Avatar
What he said
Old Apr 18, 2009 | 03:08 AM
Geeper4x4's Avatar
It will be fine.
Old Apr 18, 2009 | 04:35 AM
09rubicon's Avatar
Got the same lift on mine, it works great!! Just listen to the advice above. Rear Swaybar links moved to front, new longer links (come with the kit) on the rear.
