Best paint to use for painting factory wheels
Old Apr 19, 2009 | 01:07 PM
dlincoln91's Avatar
Default Best paint to use for painting factory wheels
i want to paint my wheels until i get my blacks ones this summer
i know i want to sand them and use a self etching primer but then what type of paint
i was told a spray on bedliner will not really harder up so then what should i use
i like a texted paint
Old Apr 19, 2009 | 01:09 PM
RedneckJeep's Avatar
Powder coat.
Old Apr 19, 2009 | 02:25 PM
blockrockin's Avatar
yeah powder coat is nice , but expensive... Ive had good luck with duplicolor high heat engine enamel . the flat black looks nice.
Old Apr 19, 2009 | 03:43 PM
For 189 bucks, you can get the Eastwood powder coating kit.
http://www.eastwoodco.com/shopping/product/detailmain.jsp?itemID=16394&itemType=PRODUCT&iMain Cat=459&iSubCat=460&iProductID=16394
Comes with 2LBS. of your choice color powder and everything you need. You can pick up an old oven from a flea market cheap and have all you need. You can make you money back powder coating things for your friends. It's a very simple process.
Old Apr 19, 2009 | 03:57 PM
hmmm that would be nice... you just need a extra oven to bake whatever you powder coat right. i would love to have a powder coater.. i would coat everything.
Old Apr 20, 2009 | 12:33 PM
dlincoln91's Avatar
i put dupkicolor on it with a self etching primer on it and it still has not hardened
Old Apr 20, 2009 | 02:22 PM
armycop's Avatar
Duplicolor makes a wheel coating specifically for rims. Its pretty cheap and at all auto parts stores.
Old Apr 20, 2009 | 02:42 PM
ricrac12525's Avatar
Default painting wheels
I painted a set of steel wheels on my old Nissan P-up with Epoxy enamel appliance paint from Home Depot, rattle can stuff. The trick is the prep of the wheel before painting , I used a scuff pad and brake cleaner then washed w/ dish detergent/water ,let dry completely and spray away. let the paint dry about 48 hrs before mounting tires.
