Problem with front brake line...
Old Apr 20, 2009 | 01:55 PM
STUPIDFACE's Avatar
Default Problem with front brake line...
Has anyone ever seen this happen?
I noticed at after doing a little wheelin'. I tried to mess with it and see if i could straighten it out, but i dont see how i could fix it without taking the brake line off. I did flex it some more after noticing the problem and everything went fine, but im afraid that it may turn into a problem later.
corey d
Old Apr 20, 2009 | 03:46 PM
paramaniac's Avatar
UH.....
havent seen that before. have you tried flexing the front end again, maybe it will just "fix itself"?
im lost on this one
Old Apr 21, 2009 | 09:03 AM
STUPIDFACE's Avatar
I never artificially flexed it, but i have flexed it in the field. I was hoping it would fix itself also. Maybe ill use a forklift to flex it and see if i can make it go back. Im gonna wind up changing the break lines eventually, but wasnt planning on it now.
corey d
