Northridge OME Lift Kit
Just got a call from my garage telling me the Currie rear sway bar links are not fitting on my 09 JK with stock wheels.
Anyone else having this problem??
David
I have the same lift, links, etc on stock wheels. The clearance is tight (like 1/8 of an inch) between the endlink and the inner wheel lip. Mine will tap the wheel when making a very tight corner, but they do not contact the wheel during normal driving. Have about 4500 miles of driving since adding the lift.
Hmmmm. My garage said the rubbing is real bad (so bad so it's not drivable). What would cause the install on one Jeep to have severe rub and no rub on another? There shouldn't be any variance between installs should there??
Is it rubbing on both sides? They might not have centered the axle correctly.
Did they say if both sides are rubbing real bad or only one? The axle may not be centered. Did you get adjustable track bars with the kit?
