Minimum Lift Needed to Clear 35" Tires?
Old Apr 21, 2009 | 06:52 AM
Skippman's Avatar
Default Minimum Lift Needed to Clear 35" Tires?
As people who've seen my other posts know my garage is pretty low. I'm trying to make arrangements with a local Jeeper to see if we can fit a 2.5" Teraflex lift w/ some 35" tires in there but I have a feeling it's gonna be to close. If I can make the Teraflex fit I'm gonna just get that. But I need to consider other options.
What is the minimum lift needed to clear 35" tires without rubbing. I know 2.5" will do it, but will a 2" lift clear? Any brand recommendations?
Old Apr 21, 2009 | 06:58 AM
Beta-pg's Avatar
Daystar has packaged thier 1.75" budget boost with thier 1" body lift and is marketing it with the "clear those 35's" catch phrase. I had 315/70/17's on a 2.5" rough country along with a 3/4" spacer added to the front, but I also ran a 1" body lift as well.
Just remember the backspacing on your wheels. If you are planning on using the stock wheels, your gonna have to add some spacers either the Teraflex, Spidertrax or the new Rough Country ones. Stay with those as apposed to the sandwich style and you'll be fine.
Old Apr 21, 2009 | 06:59 AM
greenamphibious's Avatar
tf 2.5 is more than enough to clear 35s.
Old Apr 21, 2009 | 07:10 AM
hyatt147's Avatar
Stock hahaha
just a little rubbingggg ok a good amount of rubbing and a fear of bumps
Old Apr 21, 2009 | 07:11 AM
Beta-pg's Avatar
There could still be rubbing with a 2.5" lift. Just so you have a heads up. When I first installed a 2.5" BB on my '07 unlimited, I ran 295/75R16's on the stock 16's with the Spidertrax spacers and still had a little rubbing.
But nothing that would cause me to NOT run it. I replaced my stock wheels with a steel wheel that ran 4" backspacing, added a 1" bodylift and upgraded tires to 35's. Life was good.
Old Apr 21, 2009 | 07:15 AM
jkkat's Avatar
as long as you run longer bump stops you could put them on stock.
Old Apr 21, 2009 | 07:46 AM
Schantin's Avatar
Are you against trimming the plastic fender flares? Pics in the write-up section show that you can darn near run 35's on the stock suspension once this is done. Doesn't look bad either.
Old Apr 21, 2009 | 09:49 AM
Octogoogles's Avatar
I have the OME Long Travel lift from Northridge wich gave me just over 3" of lift and although it does not rub in the wheel well I rub when cranked over and reversing on my front bumper. A saw fixed that though
Old Apr 21, 2009 | 09:52 AM
Skippman's Avatar
Yeah, I realize the RC lift needs new swaybar mounts & bump stops. Kit prices for RC and TF are about the same after all the extra parts so price really isn't a concern. I just wanna clear the 35" tires and the skid plates.
Old Apr 21, 2009 | 11:07 AM
RedneckJeep's Avatar
Originally Posted by planman
Plus a 1" body lift and flat flares. Running the extended rear bumpstops that came with the TF 2.5" lift, but still on stock front bumpstops.
Cool. Do you have any rubbing at all?
