Daystar 1.75" coil spacer up front - might need adj trackbar?
I installed the 1.75" Daystar coil spacer last night to level out my 09 Sahara 4 door. I removed the factory spacer just to be sure I did not lift it too far. I have the stock bumper and stock suspension. After doing the replacement it appears the axle has shifted 1/4" to 3/8" to the driver side. Also it appears the sway bar connects do not quite line up at a 90 degree angle and also the steering wheel is just ever so slightly out of center now. I would guess the stock spacer is 1/2 inch so the net gain in height is about 1.25". It sure looks like I need an adjustable trackbar but I do not remember anyone ever mentioning this problem when leveling out the front.
Anybody else ever heard of this problem?
I did the Daystar 1 3/4 spacer in front and the 3/4 in the rear to level my Rubicon out after adding a front bumper and winch. I left the factory spacers in and everything is rolling fine. Don't worry - I don't.
