Wheel spacers with hub rings??
Old Apr 21, 2009 | 06:54 PM
WindyCityGuy's Avatar
Default Wheel spacers with hub rings??
Ok.
I just lifted my 09 Rubicon (Used the Northridge OME lift) and my sway bar links are rubbing my 35" X 15.5" BFG Mud Terrains in the rear. I have Cragar soft 8 17" X 9" wheels but my backspacing is 5" and not enough to clear the links.
So.
I think I need to use spacers to get the backspacing I need, but the Cragar Soft 8's are lug centric so I am thinking I also need hub rings as well (god I NEVER thought I would know this much about a Jeep...).
Can I put wheel spacers and hub rings on at the same time?
Old Apr 21, 2009 | 07:05 PM
JKJosh's Avatar
Sounds like you have mounted them wrong. Let me try to find a pic. Bolt the bottom on the other side of the tab......
Old Apr 21, 2009 | 07:39 PM
mkjeep's Avatar
Move your swaybar links to inside the mounts.
Old Apr 27, 2009 | 12:23 PM
Yea I tried but unfortunately the bolt threads extend through the mount by as much as the bolt head so I need almost the same clearance either way I install them....
Could I add a nut to the bolt to act as a spacer before I put the bolt through the mount? That would shorten the amount of bolt coming through the hole and maybe give me enough clearance...
Old Apr 27, 2009 | 12:27 PM
evanyj350's Avatar
Cut the bolt.....
