Hub Centric Help - Procomp 7005 owners
Old Apr 21, 2009 | 07:49 PM
richd748's Avatar
Default Hub Centric Help - Procomp 7005 owners
I have the procomp 7005 17x9 and it states they are not hub centric. I assume from the reading I should correct this. Is anyone else running 7005's that have added rings?
Old Apr 21, 2009 | 08:09 PM
SilverGhost's Avatar
Very few aftermarket rims are hub centric. When installing the rims, bring the lug nuts to torque in 3-4 steps (i.e. 35, 65, 95, etc) in a star pattern and you will have few problems. There are some numb nuts that crank on the lug nuts with an impact wrench and the rims can be slightly off-center. Make sure you get the correct lug nuts for rim as well (Al and steel wheels use different nuts as a general rule). If you are having problems (i.e. shake) you can get hub spacers, but you may lose your center caps.
Old Apr 21, 2009 | 08:11 PM
bly109's Avatar
7005's here and no problems. As Silverghost said, just becareful tightening the lugs and you wont have any issues.
Old Apr 22, 2009 | 11:56 AM
texastvr2's Avatar
Funny, I asked the same question about my 7089s when i ordered them. I was told that no hubcentric rings are needed - there should be no problem installing them if you follow SilverGhost's instructions above.
Old Apr 22, 2009 | 05:21 PM
JackMac4's Avatar
If you call procomp, they'll tell you all their rims are designed lug centric and that no hub-centric ring is needed.
Old Apr 23, 2009 | 08:23 PM
Hellbound13's Avatar
Whatever Procomp tells you, I noticed my ride was much smooth once they were installed as they help center the wheel.
