JE REEL Direct replacement Driveshaft (rear)
So I was going to go with Tom Woods rear driveshaft but I was going to have to pay my Jeep tech to install the yokes.
I was reading the new issue of JP and saw they used a JE REEL direct bolt in replacement U-jointed/double-cardaan rear driveshaft that just bolts to the factory yokes.
Would I be good using this? Keeping in mind that my wheeling is mostly Ontario Canada trails...not serious rock-crawling or mud bogging?
i am running the Reel 1350 direct bolt on shaft in the rear now and don't have any problems what so ever. however, i was running a front shaft as well and what Chris_CH said is all true - it basically doesn't work all that well. if you are looking for a good bolt on setup for up front, i would go with a coast shaft as it comes with adapters and works very well - i am running a 1350 one now and don't have any problems.
Neg, front is all good as I run a manual tranny...it's the rear and I was looking to save a few $$$ by going with the JE REEL bolt in but if that is the case then I'll run the Tom Woods with new yokes.
Doesn't the je reel come as either a 1310 cv or use the original flange, there's also the 1350 version. I know there's three different je reels available. Which ones are bad? I think I have the 1310 that replaced the stock flange.
Mr. Reel was at Moab (Jim I think was his name). Real nice guy, just call him and get his suggestion (would probably be better than asking on here and trying to figure out which of us to believe). He was very easy to talk to, clearly very knowledgable. I've had both his shafts on my 2 dr 08 and had him come outside and just take a look and he was more than happy to do so. Said it all looked great. And yes they have 3 set-ups for JK's. I think I have the middle option.
