How far up on pinch seam
Was wondering how far up from the on the pinch seam from the rockers are ou guys trimming or pounding over. I have a Procomp 4" stage II lift with 1" spacers on the front and the rear. I also have a more 1 inch body lift and xenon narrow flares with 37" bfg's on cragar 8's
My problem is i want to remove the body lift and just have suspension. I have trimmed a good bit off the pinch seam near the rocker but it still rubs farther up into the wheel well, if you were looking at it like a clock it rubs at about 10 oclock inside the wheel well.. I was wondering if you are trimming all that out or would it be better to just get a longer bumpstop. Does having a loger bumpstop affect the down travel on opposite side
Thanks for the help
Thanks for the help
i just used a sawzall and cut diagonally. probably cut about an inch off. then i got some duplicolor bedliner, sanded and the sprayed it. that stuff looks so good im gonna do all the wheel wells.
Would be great to see a pic.
Thanks for the help
Thanks for the help
It's been discussed several times before with tons of pictures.
https://www.jk-forum.com/forums/show...ght=pinch+seam
