What color paint matches fenders/steel bumpers
I need to sand a bit of rust off of some ehanced Rubi rock rails. What color paint matches our fenders and Mopar steel bumpers?
Obviously, not gloss black. Plain black? Flat black?
I just have a little surface rust to eliminate, but figured I'd paint the entire part.
Thanks!
(was not sure if painting a part = modified...may need to move the thread)
Thanks!
It all depends on the paint manufacturer as well. If I were out shopping and needed to pick up a can I would go straight for the flat. The Mopar Off-road bumper is about as flat as you can get. If you paint a small area and find that it doesn't quite match your desires than you can always get the next step up that has slightly more gloss.
I know of this "One-Step Rust Converter Primer" that workered really well on my 59' truck frame. This stuff sprays on and chemically reacts to convert rust into a hard black primer sealer. It might be the simi-flat black you are looking for
without the sanding.
