sag caused by bumper/winch
just curious about how much sag people are getting from aftermarket bumpers with winches? and what they did or are doing to remedy it. i have a rr xhd stinger bumper on back order and will be putting a superwinch 9 synthetic on it and im already pushing it with tires, thanks
Full inch of sag with my Warn XD9000 with steel cable and Mopar bumper.
I have stock springs + a 3.25" of BB spacer lift. Of course the spacers do not sag, so mine is a pretty good indicator of the sag you'll get with stock springs.
I plan to drop the BB spacer and stock springs and replace them with a 3" HD spring from Northridge at some point. I'm not actually rubbing, but I like the leveled out look much better.
Check my profile for specifics.
Factory stock your jeep should be about 3/4" lower in the front. When I added just the ARB bumper it dropped another 3/4". I did the TF lift between adding the bumper and the winch so I am not sure how much more it would drop after the winch. I would expect at least another 1/2". You can get a 1" spacer from Teraflex which would bring you back to stock, or close to or you can get a 1 3/4" spacer from daystar which would bring the front close to level with the back which is where it should be anyway.
No other mods are necessary because you are only bringing it back to stock height. It is a really easy mod too, you should have it done in less than an hour and they only cost like $40.
I had a 2.5" budget boost spacer lift on my 4 door and put a homeade bumper and 12000LB winch and it sagged like crazy. I ordered ome heavy rate springs on it to bring it back up. They came from northridge 4x4.
I will let you know
