35'' tire pressure
Old Apr 28, 2009 | 02:02 PM
hunterbug's Avatar
Default 35'' tire pressure
Hello All,
what tire preassure are you running on the street and off road ?
Thanks to all who reply,
HunterBug
Old Apr 28, 2009 | 02:05 PM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
Originally Posted by hunterbug
Hello All,
HunterBug
28-30 street
15 offroad
Some crack head tire shops fill these things to the max pressure on the side of the tire which makes them ride like you are on rocks
Old Apr 28, 2009 | 02:06 PM
jasona33's Avatar
30-35 on the street, 15-18 depending on the trail. This past week in Moab I was running 18 and it was a perfect!
Old Apr 28, 2009 | 02:13 PM
hunterbug's Avatar
I wonder how much rim size effects the tire pressure ?
HunterBug
Old Apr 28, 2009 | 02:14 PM
VEGASSMAN's Avatar
I run 40psi on street highway, usually 12-15psi off road.
No signs of irregular wear. Noticeably better mpg than when I was running 35psi on them.
Old Apr 28, 2009 | 02:15 PM
N2MWL's Avatar
Originally Posted by tkob1060
28-30 street
15 offroad
Yes they will, mine were like 40lbs after I got the Jeep back from the tire shop..
30lbs for me, I'm on X-treme AT's.....15 or so for offroad..
Old Apr 28, 2009 | 02:27 PM
NTXJK's Avatar
30-35 on street and 13 off road
Old Apr 28, 2009 | 02:53 PM
jkkat's Avatar
for my Pro Comp X-terrains 35x12.50x17 on 17x8 rims i run 33 on road and between 8 and 15 off-road depending on conditions.
Old Apr 28, 2009 | 03:02 PM
Michigan Mike's Avatar
I run 28 PSI on road (as determined by the "chalk test") and off road typically 10-14 PSI (as determined by the "kidney test").
These are Toyo 35's on Procomp 17x9's.
Old Apr 28, 2009 | 05:08 PM
hunterbug's Avatar
Today I got my 35'' Toyo mt and my 20'' addicts. They were delivered balanced and mounted. Due to all of my excitement I never took the time to check the tire pressure , during the first moments of driving i was like holy %$#@ this this ride is so hard i cant take it . Several moments later with my new 3 dollar kmart tire guage checked the pressure and it was 60 lbs I aired down the tire to 40 lbs and the ride was awesume . for a while there I was regretting getting the wheels and was wishing I had left things alone . over the next few days I'll mess around with different pressures to see what works best . sorry for not having pics but i will be posting some soon. also the lift i have is a 3'' BDS and I couldn't be happier
