Mopar bumper with rocker guard
Old Apr 28, 2009 | 05:45 PM
scbesse's Avatar
Default Mopar bumper with rocker guard
I just finished grinding off the crush cans, adding d rings(from a Ruggid Ridge bumper), and then sprayed with 1 can of $7 Rocker Guard from Canadian tire!!!!! I love the look of it. Now to put it on the Jeep! And yes i am going to fill the bolt holes and paint them up. still needs another coat but I am loving the look so far.
Old Apr 28, 2009 | 06:12 PM
whtIwrk4's Avatar
Looks really good buddy! Congrats, nice work.
Old Apr 29, 2009 | 03:48 AM
2Summer's Avatar
looks good.
Old Apr 29, 2009 | 03:52 AM
greenamphibious's Avatar
I've notice with RR and a few other bumpers that they use bolt on plates for recovery points.... anyone ever had any issues with that? I would think they would rip right out with a good jerk. Usually clevis type mounts are welded on
Old Apr 29, 2009 | 04:33 AM
Captain Hook's Avatar
I can't believe that you sprayed right over the bird crap that I had left on there for you!
It's a sad, sad day.
Looking good though.
Old Apr 29, 2009 | 07:02 AM
Originally Posted by eisenjj
I should not be a problem at all as long as the proper grade and diameter bolts are used. The military use shackle/clevis mounts called helicopter hooks that are mounted to vehicles using bolts. Check out the Sarge concept from SEMA, it has them front and rear.
Ya I was referring more toward the integrity of the bumper than the bolts... I mean grade 8 and above would be more that effective... just curious... it wasn't until the JKs that I started seeing this so much. Bumper looks great though
Old Apr 29, 2009 | 08:19 AM
scbesse's Avatar
I am confident that the 4 bolts per shackle will hold. Yes I used grade 8 bolts. So the bumper will rip off the jeep first.thanks for the comments I can't wait to get it on tonight!
Old Apr 29, 2009 | 10:22 AM
shredX's Avatar
Those bolts go through the bumper. If you pulled hard enought to cause a failure, the bumper would probably not even be damgaged. Just the frame where it mounts or the bolts.
Old Apr 29, 2009 | 04:01 PM
scbesse's Avatar
HAHAHA Its on now. Just need the winch next!!!!!
Old Apr 29, 2009 | 04:15 PM
Piginajeep's Avatar
yeah, it'll be fine!
Looks good!
