1000.00 for a lift what do i do
I have the Teraflex 3". You can get the entry level 3" with shocks under $1k. Then you can add flex arms later. I also think the Rancho Sport lift is a brilliant lift design, it uses brackets to drop your current control arms down into correct geometry. I would get the Teraflex kit though.
I think I would need flat fenders or a chop as stated above to run 37s. I have 35s on it:
If it is too tall for you then the 2.5" tera coil kit is awesome. It gives about 3" in the front and about 2" in the rear. I think it is a good looking lift.
