Wheel spacer torque?
Old Apr 30, 2009 | 06:00 AM
jayrav's Avatar
Default Wheel spacer torque?
I will be installing a set of Teraflex wheel spacers today. How much torque is needed?
Thanks!
Old Apr 30, 2009 | 06:44 AM
JIMBOX's Avatar
Torque down in star pattern, using LOC-TITE
Thanks!
Torque value is 80/90 lb/ft, then REDO after 500 miles
JIMBO
Old Apr 30, 2009 | 06:46 AM
jayrav's Avatar
JIMBO
Thanks, but which loc-tite should I use?
Old Apr 30, 2009 | 06:47 AM
IMFletch's Avatar
Don't know about the TF spacers but Spidertrax recommends 90 ft lbs. Some forum members have reported going as high as 105 ft lbs.
Old Apr 30, 2009 | 06:49 AM
IMFletch's Avatar
Use red locktite on the spacer threads.
Old Apr 30, 2009 | 07:12 AM
JeffD's Avatar
Red Locktite is used for a more permanent set, and I went 100 ftlb figuring I would check them soon at 90 ftlbs so as to not break loose the locktite.
Old Apr 30, 2009 | 08:27 AM
Northridge4x4's Avatar
Sponsoring Vendor
They did not come with loctite and instructions?
David
Old Apr 30, 2009 | 09:03 AM
jayrav's Avatar
David
No loctite and the instructions don't go into detail :-(
Old Apr 30, 2009 | 09:27 AM
TeraFlex's Avatar
Sponsoring Manufacturer
Nice no torque specs on instructions. TeraFlex is updating those instructions now, jayrav thanks for the call.
85lbs
Old Apr 30, 2009 | 09:37 AM
DtownJK's Avatar
Been running my Teraflex spacers for about 8 months no issues they have worked great. Used Red Loctite. I now have to get them off since I have the new rims and tires siting in the garage. Any advice on getting them off since I used the Loctite. I have never used that stuff before. Will it just bust loose?
