Tranny Cooler
Old May 4, 2009 | 12:13 PM
Wheelerbob's Avatar
Default Tranny Cooler
Are any vendors on here offering a bolt on plug and play tranny cooler for us auto guys. Yes I can fit one on myself but I thought it would be nice to have a kit with pre bent lines, fittings,etc. Just wondering because I want to install one before summer gets here.
Old May 4, 2009 | 01:21 PM
atuldo's Avatar
are you overheating,did you flush and changed fluid,or you just want to install one...
Old May 4, 2009 | 01:32 PM
RedneckJeep's Avatar
No. No one offers a plug and play cooler for the JK. The lines have special connectors on them. Here is how I did mine.
https://www.jk-forum.com/forums/jk-write-ups-39/trans-cooler-hard-line-install-58529/
Old May 7, 2009 | 11:39 AM
den92179's Avatar
why would you want one i have a trans temp gauge in my 2008 and i have
not seen it go past 161 it is and auto meter digital gauge. i had it in the pressure line then switch it to the return line with not much difference.
Old May 7, 2009 | 11:57 AM
eaglemikeo's Avatar
is this the tranny cooler you were looking for?
Old May 7, 2009 | 12:19 PM
RCJeeper's Avatar
A JK auto fitted with 35" and stock gears will see high temps on long mountain ascents. Even with a trans cooler I've seen mine hit 225° in the mountains. A transmission cooler is almost never a bad idea. See this thread regarding the PO218 trouble code for transmission over heating.
https://www.jk-forum.com/forums/show...nsmission+ding
