sure wish my LoD sliders would fit!
Old May 4, 2009 | 01:28 PM
Biggerjeep's Avatar
Default sure wish my LoD sliders would fit!
My lod slides wont bolt on due to the relocation of the brackets from my lift kit
Long Arm Terraflex...
So ...... if i cut the tabs off the sliders front mounting bracket and custom cut the rear , get them to match up to the frame and weld them on, Will this pose any problems in the future.??
Old May 4, 2009 | 01:30 PM
Robar's Avatar
Only if you want to remove them.
Old May 4, 2009 | 01:43 PM
Biggerjeep's Avatar
What about frame issues where its welded?
Old May 4, 2009 | 01:46 PM
Robar's Avatar
I wouldn't think so unless you burned through the frame. The EVO sliders are welded directly to the frame and others have welded sliders to the frame. You should be OK.
