View Poll Results: Which combo for high altitude driving
Voters: 10. You may not vote on this poll
6-Speed, 295 or 315, 4.56 or 4.88, Altitude
Guest
Posts: n/a
Gents,
Looking for advice. I have read a lot of the gearing threads and thanks for all the info. My Rusty's 3.25 lift is going on next tuesday. I am a road warrior and light trail user ( no crawling ).
Here is the x-factor, I live in colorado and drive at 5280 - 10000 feet. I do drive quite a bit up I70 and 285 to get to my favorite trout holes.
So what combo would you go with on a 6 speed manual to get up and down the mountains and daily drive.
4.56 w/ 295/75r16
4.88 w/ 295/75r16
4.56 w/ 315/75r16
4.88 w/ 315/75r16
Thanks in advance!
And advice on rear tire mounting options is also welcome!
4.56 w/ 295/75r16
4.88 w/ 295/75r16
4.56 w/ 315/75r16
4.88 w/ 315/75r16
Thanks in advance!
I would tend to agree with the 4.88s at a minimum. If this was an automatic you would be thirsting for more with 5.38s. After you get your lift and tires I would roll it around on your typical cruises and find out what gear you are downshifting into. If you aren't rolling back to 4th, the 4.88s will be fine and if you are 5.13s might be a better call.
How much gear do you typically carry and any armor or bumpers?
Gents,
4.56 w/ 295/75r16
4.88 w/ 295/75r16
4.56 w/ 315/75r16
4.88 w/ 315/75r16
Thanks in advance!
4.56 w/ 295/75r16
4.88 w/ 295/75r16
4.56 w/ 315/75r16
4.88 w/ 315/75r16
Thanks in advance!
I would think you would do best with 4.88's and 33's unless you need the additional inch the 35's will give you. More power than with 35's.
