Diamond plate on Doors
Old Jul 15, 2009 | 07:02 AM
Zee's Avatar
Zee
Default Diamond plate on Doors
Is there such a thing as diamond plate to put on the doors. I would love to get the doors covered 3/4 of the way up with black powder coated diamond plate.
I have seen diamond plate 1/2 doors, But I don't remember seeing anything that would cover existing doors.
Old Jul 15, 2009 | 07:46 AM
CitadelJeep04's Avatar
Go find a metal fab shop and have them cut out some diamond plate for you and then bolt it on to your doors.
Old Jul 15, 2009 | 07:57 AM
Zee's Avatar
Zee
Any ideas on sealing it to the paint to prevent moisture from getting trapped in between?
Old Jul 15, 2009 | 08:44 AM
STUPIDFACE's Avatar
I wouldnt try to seal moisture out. You would probably use nutserts to attach the plate to the doors and there is a small flange (on the nutserts) that will hold the plate maybe 1/32 or less from the paint. This would allow water to get in and out. If you insist on sealing it, you could probably use some silicone or something and shoot a bead just inside the edge of the diamond plate before you put it on. After you tingten down the nutserts, just wipe off what squeezes out. Thats what i was going to do when i installed my evo quarter armor. Once i got into the install i fugured sealing it would be a mess and probably do more harm than good.
corey d
Old Jul 15, 2009 | 09:07 AM
Zee's Avatar
Zee
That's a good point. Thanks for the info... black diamond plate on doors will look badass I think, and protect them as well.
Old Jul 15, 2009 | 01:53 PM
pastorsteve's Avatar
Yep. If you look at any fire engine you'll see very creative ways to cover a vehicle with diamond-plate. Just cut to shape and install.
