Question on Teraflex 3" lift
I Just wanted to know if this lift uses cam bolts or not. Trying to stay away from cam bolts if possible. And if anyone is running this lift, how are you liking it?
Like he said!!! I run the 3" with the full set of arms from Teraflex as well as adjustible front and rear track bars. Teraflex products are very will built. Good luck with your Jeep and don't forget to post before and after shots when you are done.
I also have the tera 3". I got mine with 4 control arms. (front lowers, rear uppers) Then I added the front uppers and rear lowers later. The kit is great, and Teraflex is awesome. No matter what kit you get, DO NOT get cam bolts. I would rather drive around with shallow caster as I saved monoey for front lowers. As far as I know Tera uses no cam bolts on any of their products.
